Cement disbond from block foundation wall
MikeC55
CT
The garage is in CT and so does see freezing temperatures in winter. I think the cement covering is mostly cosmetic but it's probably a good idea to try and keep the foundation block from being exposed to direct moisture. I suspect the whole side will peel off pretty easy. Would you normally expect the cement to bond better to block? Should I re-stucco?
billconner
Thousand Islands NYS
I would not expect that failure.
Yes, remove all that is loose, power wash, and apply a fibered coating. Be sure to dampen the base before application. I like Conpro Foundation Coat but sure there are others. I'd probably add their K-88 Admix.
It's tough on the elbows.
BillK
Beautiful Southern Maryland
Looks to me like something is pushing it out at that point ? Look at where my arrow is pointing. What is that ?? I think you need to peel the rest off in that area and take a good look at what is happening.
MikeC55
CT
Thanks Bill. There aren't too many places that in my neck of the woods that sell that brand and I called two of them and they would have to special order it. Anyone else have experience with a similar product that is more available?
MikeC55
CT
I did notice that BillK and need to investigate further. I know the wall is only one block thick and when looking in that area on inside, I don't see anything wrong. I may have to remove the shingle to get to the bottom of it.
billconner
Quickrete Quickwall - big box store. There are others - surface bonding cement. Waterproof and structural.
MikeC55
CT
Thanks Bill,
My local HD has Rapid Set waterproofing mortar, a cementitious coating which seems like it would do the job, at least for a short term repair before winter sets in.
The Cobbler
very typical with parging to fail like that . newer fiber entrained parging will hold up better than old simple mortar based does . I would be quite certain you don't have any issues . parging is merely cosmetic, it's not a protectant for the concrete block, the block will survive just fine without it . look at commercial buildings built with cement block, they last forever without a parge coat on them
billconner
Mike - my HD has the quickwall. fwiw.
It does add waterproofing. As I read, surface bonding cement (which includes fiberglass fibers) was developed initially to build water tanks. I don't know if those were drylaid or mortared. So not needed to protect the block but perhaps more than aesthetic.
Uncle murph
Harford county
What you’re seeing is the result of freezing,the only question is when,the separation may have occurred years ago and it’s just now falling off.Properly applied parging is almost impossible to remove,but if it froze while still green the bond was ruined at the beginning.
MikeC55
CT
Thanks all. It's quite possible it started disbonding long ago and the block coming loose near the top is what started it spalling off. I'll check and see if those other products are easily available around here.
Monza Harry
Windsor ON
While I'm far from an expert on these matters, I do have some experience, I can't see a drip edge at the siding/CMU interface, [possible water entrance point] and those blocks are open on the inside also allowing moisture/condensation to enter and freeze further exasperating the situation. Vapour barrier or blueskin wouldn’t be a horrible plan IMHO. Clean/prep and re-parge after the root cause is remedied. Harry
mikedodge
We've had ours come off several times in one spot simply from poor adhesion. Finally found the right person to fix it and it's been fine ever since.
MikeC55
CT
Monza, the shingles overlap the top of the block wall but I don't know if there's any tar paper under there (garage was built in early 60's). But I am sure letting water get to the interior of the blocks is definitely to be avoided.
Mr_fixit
Rustylvania
I have a similar problem. But my problem seems to be moisture wicking up the block behind the new stucco type covering. It cracks when it freezes and thaws, freezes, again, cracks more until it falls off in sheets. Maybe your problem is different ?
yeldogt
It is important to wet the surface ... I think this is the most important part. Typically you get a failure after a crack occures and water gets behind .... especially in cold climates. I have had it crack w/o having any visable problmes with the block .... but -- normally the block moves or cracks. Best to imbed some of that fiberglass tape they use on drywall .... have had good luck with that.
The products sold as stucco work the best when doing large areas .... I have used all kinds of stuff to patch old walls. Even the patching cement on the plastic tubs. If I was mixing it -- add lime for stick and flex. On my old houses I use lime mortar
duneslider
Riverton, Utah
Its pretty normal for that parge coat to come off in sheets after a bunch of years, especially if it wasn't bonded really well. Most of the time I see the guys putting it on dry walls in direct sunlight. It never really bonds well to the wall and after a handful of years it pops off. It is mostly just cosmetic.
When I have done it I just mixed sand, portland, lime. You trowel it on and then rub is smooth with a float. The key to it lasting is making sure the wall is clean and damp and you aren't doing it in hot direct sunlight. You can add bonding agents to the wall first but they shouldn't be needed. My local HD and Lowes carry a foundation plaster which I assume is probably a stucco finish coat cement which some call a brown coat. Its been a while but I think I used to use 6 parts sand, 2-3 parts lime, 1 part portland when I did it. I always used the nicer silica sand for this too, it has a more uniform size and I thought looked nicer than play sand or the other bagged sands.
CarBikeGuy70
Western CT
As others have said the issue is adhesion of skim coat/stucco finish to block wall. You need to remove old coating - keep removing it until you are working hard to do so, or you will be repeating process sooner than you think.. Remember to dig down below grade and reapply coating well below your final grade. Prep is issue - follow what others have said about a clean and damp surface to work with. HD sells a pre formed drip edge that you can slide under the bottom course of shakes and it will push the water away from the wall .
dogdog
It's just Type-N mortar and fine sand... but you have to remove the alge (green and anything moldy , or loose) chip it off, pressure wash, treat the alge, mix 1:3 (type-N to sand) you can even use some acrylic adhesion promoter, trowel it on. Paint it white, those water proofing thing paints.
MikeC55
CT
So I had some time today to look closer at what was going on here with that one block pushing out and causing (or at least accelerating) the parge disbond. The block was loose and after removing a couple of shingles, and some scraping of the mortar joints, I was able to remove the outer face of the block. The first thing I notice is the squarish rust spot internal to the block. At first I thought a metal object got dropped into the concrete when the block was cast but after removing a few pieces of the cracked internal webbing of the block, it became clear I was looking at a cast-in J-bolt. I guess this was a thing in the early 60's if you weren't going to pour a cap on your concrete block foundation wall. It appears enough moisture got to the bolt that rust expanded it and forced the block apart.
Funny thing is, the bolt must only go through the 2x6 that lies on top of the block and not the bottom 2x4 of wall. Seems strand that these bolts would go through both but without hurricane clips, etc., I guess it wouldn't make much difference. I could cut the bolt and carefully remove the rest of the block and cement in a new one, I was thinking I might also stick some rebar down in the block holes and thin fill the accessible block holes with concrete as well.
To the left of this block, down to about 8" above grade, the parge was cracked and disbonded for sever feet but this appears to simply be poor adhesion. Maybe the block was not clean closer to grade level when parge was applied.
