Cement mixer question?..
bmxdukie
Ontario, Canada
Hey folks! I have an old electric cement mixer a buddy gave me.
It has a burnt out electric motor.
That said i have a baldor electric motor that has a weight on the shaft from my wifes old treadmill. Would this work for the mixer? I know the motor is variable speed. Maybe a speed controller?
Spareparts
Lansing Ks.
That might have a DC motor with a speed control, the whole thing might have to be used. I think mine had a 1/2 hp motor on it, it has to be sealed type, but with that sais I have seen many mixers with a open motor with a shield over it to keep the moisture out.
Bert_
NW Iowa
A 5hp motor would draw over 50 amps if you could find one that ran on 120v...
How big is the old motor on the mixer?
Showkey
"MEMBER EMERITUS"
Wausau WI
strutaeng
Dallas, TX
Concrete mixer have a huge gear advantage..........1/3 to 1/2 HP electric is all that need for 2 bag mixer size.
Typical 2cubic ft mixer :
Easy-to-clean polypropylene drum
2 cu. ft. drum capacity
0.88 cu. ft. mixing capacity
Holds up to 108 lbs. of premix
250 Watt, 1/3 HP 120V electric motor operates at 1,720 RPM
https://www.northerntool.com/shop/t...A-3j5_lJVIBXBx_56KVleP8dSNCR0wgBoCw9wQAvD_BwE
Yes!
I bought a Kushlan 600DD and was surprised how strong it was due to the gear reduction. 3/4 HP reduced to 28 RPM according to their specs. The motor is all housed in a gearbox that required me to go to Autozone to buy gear oil because it comes dry.
I mixed 2, 1/2 cubic yard "pours" in about 30 minutes each time (about 8-10 batches each.) I mixed it by shovels of gravel/sand mix and added portland cement, so I didn't know exactly how much material was mixed per batch. The manual say 4 bags of 80 lb mix per batch.
As far as your mixer, you probably want a steep gear/belt reduction (triple reduction?) to get to spin slow with a 1725 RPM motor. Otherwise the variable speed option is the way to got.
bmxdukie
Ontario, Canada
Im on my way out to the shop tomorrow. Ill report back my findings.
Thanjs so far for the help. Im sure ill need more! Lol
atthebeach
At The Beach
Got a 1/2 hp mixer at the home despot many years ago. It was always on the ragged edge of being under powered and would occasionally stall out at the most inconvenient times. I finally replaced the motor with a 3/4 hp motor and it made all the difference in the world.
