Cement screws, what’s best?
LXCam
Interesting, I’ve never had much issue with them. Are you pre-drilling with the right size?
Beyond that, if this is a ledger tapcons wouldn’t be my choice.
gleman
Michigan And Florida too!
I think your going to need bigger fasteners for a ledger. Did you look into expansion anchors or epoxy anchors?
I've had good luck with Tapcons after I decided to follow the directions on the package, I messed up the first few thinking I knew better.
Good luck!
reader2580
Minneapolis, MN
Is this a permitted job? If so, have you checked with the building department to make sure those are acceptable fasteners? How do you think those will hold the load if they are snapping on installation?
Jeff95TA
Pittsburgh, PA
This is from the Prescriptive Residential Wood Deck Construction Guide based off of the IRC. You need 1/2" if going into solid concrete/masonry.
oldmachinenut
Missing, presumed dead in central Pa.
I had several break when tightening and never had problems in the past. On closer inspection the ones that broke were “Quality? Chiwanistan knock-offs, they were loose in a bin at the hardware store. I went back and dug out some genuine made in USA tapcons, problem solved.
Jeff95TA
Pittsburgh, PA
I can't tell if your wall is hollow masonry, but if so, it technically isn't allowed. But if you go back to an older version of the Code (shown below), they required epoxy or adhesive anchors. You can get ones that are like little umbrellas at the end of the fastener that pop open when pushed through the block. The epoxy fills the umbrella on the inside of the block.
Old tool guy
If that’s a solid concrete wall, these will work. Get it right the first time, there’s no way to remove them.
jar944
Northern VA
Depends on what version of IRC the locality is following.
Screenshot_20231016_124125_Samsung Notes.jpgScreenshot_20231016_124158_Samsung Notes.jpgScreenshot_20231016_124220_Samsung Notes.jpg
manwithtools
Lebanon, TN
Good luck!
This is very important to do, for instance most require no more than 1-1/2" of screw depth inside the masonry, otherwise they will snap off.
jkuro
These may be what you need:
Prospecter
Maine
OP . . .As others have noted, Tapcons won't cut it for a ledger board.
However, I feel your pain with Tapcons. Two tricks that help a lot. 1) Wet the drill bit between holes. 2) Blow the dust out of the holes.
gleman
The first time I had to do shelving on a block wall with Tapcons was an eye opener for me.
I read the directions on all unfamiliar stuff now.
#2 Blow out the dust. Don't half-*** try to get it out with a vacuum!
stillnostrebor
SW Missouri
The table in post #13 is what you want. Nice posting!
Tapcons are fantastic for holding stuff while you really fasten it, holding grout formwork, attaching lightweight items, etc. They are not fantastic for load bearing work, unless they are the really big expensive structural ones they sell.
BlackdogGS
The Dalles Oregon, Puget Island Washington
This is what I have available locally, I just need to figure out the diameter and length. After I get that figured out it should be an easy install. Thanks
BlackdogGS
Ya, been studying that. Looks like I need 1/2” bolts. I’m going into solid cement.
bluedog225
Texas
It’s actually lucky the tapcons broke.
On noncritical stuff, I oversized the hole and stick a piece of pine or cedar, or wire in the hole. Works great.
PoorUB
Fargo, ND
I put a deck on the back of our house. The city required 1/2" Redheads or wedge anchors I used about one per foot by their requirements.
Old tool guy
Figure you’re going to lose 2” for the thickness of the 2x and the nut, and you want the anchor 2” deep.
Criss
Western PA
I've used 1/2 simson strong tie "Titan" concrete anchors. i've seen sleeve anchors and lag shields used.
duneslider
Riverton, Utah
Wedge anchors are always accepted by cities for ledger boards. Titans are not always accepted and you may need an engineers note for that.
Most cities (in my area) nowadays are allowing Titans and epoxy anchors for sill plates without an engineer's note, however, most engineers are putting a note in their calcs that the typical 5/8 j-bolts can be replaced by the corresponding Titans or epoxy anchors.
We do a lot of anchoring to concrete at work and Titans are not always accepted and we have more issues with Titans than wedge anchors, most of our anchoring requires special inspections, so they are torque-tested and/or pull-tested. We rarely use Titans due to the amount of issues we have had with them.
Old tool guy
Take a piece of deck board, drill large holes in the back for the anchor bolts, and use it as a vanity cover for the exposed ledger.
BombShelter
State of Hockey
Nice! Just curious what you used to drive the original Tapcons, I've used my little Makita Impact and never had a head snap but I'm doing fairly small screws.
