Tbabble
Hey guys, looking for some input on a Campbell Hausfeld Compressor I found on CL today.
It is a VT6275 with supposedly an hour or so of actual use.
Here are the specs on it CH Compressor
60 gallon
3.2 HP running
Vertical tank
Cast iron, twin cylinder, oil lubricated pump
Up to 5000 hrs extended life
35% quieter and 60 degrees cooler than aluminum pumps
ASME code tank
3/4" discharge port
Integrated, easy-to-read gauges
230V motor
Air flter
135 PSI max
11.8 SCFM at 40 PSI
10.2 SCFM at 90 PSI
Dimensions: 70.5"H x 27.5"W x 29.5"D
3 year limited warranty
The guy is asking 400... at most I'd give him 320 since I have to drive and I can buy a new one for 500. From the pictures it looks like he runs a body shop, and states he only put an hour of so use on it. Maybe his main one was down and he bought it to finish a job? It looks like its still on the shipping pallet so maybe he did only use for a few hours eh?
This would be for general air tool use and to run a hypertherm powermax 45 which will require 6cf @ 90psi from what I've read. Seem's like a good enough deal to me, would you say its worth buying or should I Just go for new one / better model. Any info is appreciated, thanks for reading!
60 gallon
3.2 HP running
Vertical tank
ASME code tank
3/4" discharge port
230V motor
Air flter
135 PSI max
11.8 SCFM at 40 PSI
10.2 SCFM at 90 PSI
