Chain and Binder Storage Rack
509frank
Milton PA
Built a rack to keep the chains and binders of the garage floor. Any opinions?
BD1
north side
Looks good. It's really nice when projects get painted. i hope the wall and hold it.
509frank
Milton PA
Very beefy. I like it.
What was the drilled angle iron originally from?
I drilled the holes. The hooks are bungee strap hooks they just hold a link in the center of the chain to keep more of the chain off the floor.
509frank
Milton PA
Eack upright is lagged into a sud with 4 5/16 x 2 1/2 lag screws. I stood on the top before I took it back down for paint.
koditten
Midland, Michigan
Very nice. Can I ask why no pegs? You woudn't need the "S" hooks. I did something similar, but incorperated pegs to hang my web slings.
Regardless, very nice and plenty of room for more stuff.
Thanks for sharing.
KO
EOC_Jason
Bentonville, AR
Very nice, unfortunately I have all my chains and binders just in those milk cubes. At least I have them semi-organized with long chains in one, short chains in another, and binders in a 3rd... ;) Would be nice to have them and all various sized straps organized on the wall.
Piper
Muskoka, Canada
I agree with all above, nice job. If your chains are like mine from various jobs they get dirty/wet. I'd be putting some sort of boot drip tray or something similar under them to catch the dirt/drip ... aside from that.. I just might have to borrow your idea.. my buckets of chains just aren't doing it for me.
csp
Franktown, CO
No offense uniballer, but do you really need a drawing for something so simple? It's not like there are close tolerances that have to be followed or it won't work. ;)
I've been needing to make such a rack for a while myself. Seeing this might be the motivation I need to get it done! Thanks 509frank
tthornto
The angle with holes drilled looks similar to what you would find in a server, network, or Audio/Video equipment rack. Sometimes they can be found for reasonably cheap at an auction or from an electronics recycler. Most of them have all of the holes threaded so you could easily attach all kinds of things to them instead of just hooks.
carhunter
southern Ohio
Same here, but I can never make up my mind which I prefer - wall or crate. We use recycled parts totes from a GM plant - they're a little taller than a milk crate and about twice as deep. Great for chains and binders, but everything kinda gets coiled together in the bottom. And its heavy!
OP nice job on the rack.
Nice rack!
All my chain binders and come-a-longs are hooked on the top of the posts of my shop press, (5 X 5" box tubing), and the chain is all in a bucket.
I did do something similar out of conduit for the ratchet straps though, and out of 2x2 for most of the pipe clamps
OccupantRJ
Eastern North Carolina
Here's a simple tip on storing chain in a box or bucket. Most people are going to know this one, but you never know.......hook chain hooks over the edge of the bucket to make retrieval of a particular chain much easier. Painting the hooks different colors for each chain enhances this ability, especially if chains are of different lengths. For storing bulk or random pieces of chain that do not have hooks, cut a slot into the upper edge of the box or bucket to allow the chain to slot into, to keep up with the loose end.
