Chamberlain/Craftsman rail extension question
tundradude
Winnipeg, MB
I've just purchased two 3/4 HP Craftsman belt drive door openers. I need to purchase the 8ft rail extension for each opener. As luck would have it, there is only ONE in the entire city.
Now I know that Chamberlain makes Craftsman's openers. Would it be safe to assume that an extension kit made by Chamberlain for a similar type opener would be compatible? Has anyone run into this? To make matters worse, the guy at Sears tried to order and the part came up discontinued. Discontinued???!!!! Aren't 8' doors the norm these days?
rsanter
visalia ca
thats why I like the genie screw drive openers.
the extension kit is just putting another section of track and screw in the system
bob
nova65ss
Raleigh, NC
It would depend on if it the Chamberlain is a T-rail or a tube. The craftsman has a tube type rail not sure what the Chamberlain's are nowadays.
Galvatron
Where are you located? My Lowes has a ton of them ($39). Cant you just order online and pick up instore?
6t7gto
bedford,ohio
I needed an extension for my son's opener.
Sears site said discontinued.
Found a seller on Ebay that had 40 of them.
david
kbs2244
If you are willing to do some tinkering with hole punched angle iron on the ceiling set back from the door, you may be able to set the whole opener back from the header and just use your existing track.
Often there is 3 or 4 feet of unused track between the traveler and the header when the door is down.
You just move the opener back this amount.
They bolt them to the header just because it is an easy place to take the thrust forces.
I did this with 8 foot doors under a 10 foot ceiling.
I did have to lengthen the “J” though.
T
tundradude
Winnipeg, MB
Problem solved.
For the record, the extension kits are the same. A quick search revealed that both models used the same rail system. However, their extension kits have different part numbers. I bought the Sears one then bought the Chamberlain. Same kit. Assumption correct.
kbs2244, I might look into that, although I'm not installing them myself. I can always take the kits back.
Thanks for the help guys. :bounce:
