The house I'm living in was built with no light fixtures in the bedrooms. The switch next to the door controlled an outlet. The last owners had ceiling fans installed and wired them so that the light switch now operates the light on the ceiling fan. In order to operate the fan itself, you have to pull the chain.
I want to install rotary switch next to the light switch to operate the fan in each room. The light switch is on a 4x4 box with single gang mud ring. What do I need to do in order to install a double gang mud ring to accommodate the rotary switch? Is there any easier way than cutting out the drywall far enough to remove the current mud ring, replace it, and mud/tape again?
