Hello Hive Mind, In an earlier post I asked some questions about installing an after-cooler to my compressor. Someone posted on that earlier thread that I should install an in-line check valve between the compressor outlet and the cooler inlet to prevent any accumulated moisture in the tube from getting back into the compressor. I purchased a check valve off of Ebay and it is a Conrader CLB34.
First Question, what is the flow direction on this thing? And secondly do I need to use the unloader port or can I just put an screw in the port and seal it off?
