Chop Saw Stand or Small Mobile Table
tomshep
I have a small shop I weekend warrior in and use a chop saw on metal items a few times a month for my "projects". I am tired of dragging the chop saw outside to cut stuff and I don't like doing it inside with the cars and cutting debris.
So, has anyone found an option for some sort of a stand that could be made mobile for mounting a chop saw. I went to HF and the stands were not solid at all.
I am actually considering building a small table (2'x3'?) that doesn't take up too much floor space that I can wheel outside. The chop saw would be mounted on one end and the rest would be a small work area for little welding projects, grinding, beating on stuff, etc.
Any thoughts?
Tom
Sureshot
Bridge Creek, OK
I built a stand with wheels on the back so when you lift the handle on the front you can wheel it out. I would like to upgrade it and put disc storage underneath. I also built saw horses to match.
I made all my benches and stands either 2' or 3' tall so everything matches height wise.
BigSteve63
SW Missouri
There is a great design for a chop saw stand on one of the welding sites - if you Google "chop saw mobile workstation" you will see it fairly close to the top.:thumbup:
Well thought out design, and has the dimensions in about post #38 or so..
Steve
sberry
Brethren, Michigan
I rarely miter, I nip corners with a plasma if I do.
T
tomshep
Bill Bowman
Metro Chicago
I picked this one up several years ago at a swap meet. Looks like it would be fairly easy to fab up. Bill
akdiesel
Wasilla, AK
sberry
That looks great. Kind of like a Kiosk look the way it painted.
Bill Bowman
Great find. The supports are perfect.
crewchief888
NW indiana
i have a couple stands from HF
havent managed to mangle one in the past 5 years or so.
used some leftover 3/4" plywood for the tops, bolted in place with carriage bolts.
i have a bender mounted to one, ridgid abrasive chop saw on the other.
surprisingly sturdy, small & lightweight enough to carry from the garage down into the basement for winter storage.
what i found out with "cheap" tables, stands and carts, is to loosely bolt everything together, kinda shake it around to kinda even everything up, then tighten up all the screws.
:beer:
NUTTSGT
Northern Central Ohio
I use a HF mover's dolley that I keep my chop saw on. Since it throws sparks, I put a piece of sheet metal down under the saw. I also made a small roller stand to hold up the other end of the steel I was cutting.
Here's a link to the stand, in it you can see a picture of the chop saw on the dolley. . .. ah here's a picture of it.
EDIT btw, I keep my chop saw under the work bench, so I can just roll out around where I want it.
sberry
Brethren, Michigan
I made the thing one afternoon when I swept up chop dust again. I had experimented with some catcher stuff, had this riding one end of a bench but they are such a mess and you need to collect drops. Yes, the hose is for fresh to the motor, I could make this even more fancy, I use it frequently not a lot if that makes sense. I finally modified the front nose so it blow dross down in the bottom of the tank better. It sits on pegs to locate it.
T
tomshep
Bill,
That is what I had in mind. I like the arms that fold. I also want it on wheels so I can go outside and minimize the mess inside.
Thanks, Tom
