Chopped 51 Merc Build
D
Duke55
Utah
Not as far as I planned but that's pretty typical.
Cleaned up under the back window. Little patch prior to welding. Also welded lower seam to the center of the car.
Started to clean up door posts but didn't finish.
Quick video showing handheld p-hammer in action on TIG welded seam of 18ga steel.
https://vimeo.com/199573333
C_F
Utah...SNOW BLOWS!
Thanks for showing that, I was just about to ask a bunch of questions as to how it worked. :D It works pretty slick!
I swear I posted in this thread previously, but going back through, I see I haven't. It's hell getting old.:lol: Anyway, great work as always, I'm really enjoying watching this car slowly being smoothed out with your skilled hands. Looking forward to continued updates!
D
Duke55
Utah
Roger (pervious owner of the car I am working on) was looking through custom car pictures on Rik Hoving site and stumbled onto a couple pictures of His previous merc and sent them to me. But cooler than stumbling onto the merc pictures is that the grey chopped XL in the background is my grandpa's. Pictures were taken in 1992.
D
Duke55
Utah
Thanks guys for the comments. I am finally back to work on the merc after spending a week in Florida for work and dealing with 2.5' of new snow the first few days of last week.
Only minor updates. Small patches in the rear lower fenders. This is the only rust on the car since the front clip sat out side (it was under a roof and on concrete but not completely out of the weather).
Other side
First cut at the lower rear door window radius. The turned flange on this piece is quite a bit wider than the previous ones done. Because of that I will be doing these in two pieces.
Made a small path back to the shop this weekend.
oldmxracer
Stupid question, what do You move Your snow with ?
Love Your work, Thanks for sharing !
D
Duke55
Utah
I have a old beater 1987 case diesel skid steer that has paid for itself many times over. Normally I'd say I use it 10x as much in the summer lifting and moving things than moving snow in the winter. We'll see if this picture works. One of the only pictures I have of it on my phone is a panorama.
Tried another lower rear corner tonight.
D
Duke55
Utah
Lower rear door window radius done on both sides.
D
Duke55
Utah
Thanks for all the comments and taking the time to look.
Spent another week on travel but was able to get out and work today.
I built a deeper throat frame for the p-hammer.
Then I spent the rest of the day wheeling and cussing this panel. I would really like to make a few panels with someone who really knows the wheel to teach me a few things.
I guess I should quit complaining, at least I don't have to throw the panel away and start over.
D
Duke55
Utah
Didn't quite finish this panel today but it's getting close. Can't reach all the welds with the p-hammer so I still need to do a few sections by hand.
D
Duke55
Utah
Milking the roof some more.
D
Duke55
Utah
Thanks Robert. As for the shrinking disc I don't know any different so I like it. One of these days I'll order a ribbed disc to try.
D
Duke55
Utah
No I bought it off eBay from wolfs metal fabrication but it looks to be the same design.
D
Duke55
Utah
Made a couple 2" diameter p-hammer dies that work really good on big open panels. Need to spend a day and machine a bunch of dies.
Done some work on the drivers side quarter panel. This little slit section is how someone fixed a crease then leaded over the slit.
This section was badly pitted.
D
Duke55
Utah
That won't be happening with this one. I will get there on one of my future projects after a bit more practice.
D
Duke55
Utah
Filled the gas door and smoothed trunk lid.
Straighten rear bumper, narrowed and installed a Pontiac overrider.
Scored an Aloris CXA tool post set for the lathe.
wasfast
San Diego CA
Incredible as usual. Have you got a color scheme in mind for the '51? Certainly can't go wrong with the Aloris quick change setup. They've been around forever and just work.
D
Duke55
Utah
Currently leaning towards a solid off white and light blue fine metallic flake two tone. Thinking a clean classy look which is a bit different for me.
Can't wait to install and use the Aloris. Huge step up over what came with the lathe.
