You’re work is incredible!!!!!! Thanks for sharing !!
You and mp&c are inspiring that I need to push myself to make things better when working on my projects. Thanks
On you’re planishing hammer buid in the merc project , did you use just regular box store black (gas) pipe ?
Thank you, I am honored you mentioned me in the same context as MP&C. He inspires me to do better also.
As far as the p-hammer frames they are just black pipe. I get it from my local weld shop and it looks like DOM quality outer finish and not the typical box store rough finish. For the two smaller frames I built the 3/4” schedule 40 black pipe (~1” OD) works good. Anything with a deeper reach really needs bigger diameter pipe if using for shaping. Will work for smoothing.
