cieling attach at gable ends
Skindoo
Hello newbie to site here. Im building a garage. Foundation, walls, trusses and all exterior is covered in steel. Now starting interior. Trying to figure out how to install cieling. Think I will go with white steel by screwing the steel to the bottom of the trusses. How do I attach the ceiling at the gable ends? The end trusses are on the outer side of the top plate so when I install the steel on the bottom of the inteior trusses it will **** up against the inside of top plates so nothing to screw up into. Is it just ok to nail a 1 x 4 on the top plates that overhangs in the interior. It would be something to screw to? I hope I have explained everything as to understand.
Thanks
PS trusses are on 24" centre, plan to have plastic vapour before installing steel on ceiling, then blow in insulation.
jlckmj
SE Wiscosin
Yes, 1x4 - 2x4 - 2x2, along inside, anything that will allow you to anchor the bottom of the sheets to.
ADSR
I always use a 2x6 for more strength. 2 x 4/6 is standard.
OccupantRJ
Eastern North Carolina
In carpentry terms this is called a nailer. I am going to use 1x6 for mine because I get 12 footers salvaged from long shipping crates free from work.
