circlip pliers
littlebean
so, this being GJ, I fully expect the answer to be buy them all but..........
for general use (home diy, aircooled vw) are 45deg tips an option over buying both straight and 90 deg tips?
KnurledNut
n/a
Let me be the first to meet your expectations:
Buy them all.
(These threads usually go full circle back to the above. Ill save you the trouble.) :lol:
L
littlebean
my expectations fully fulfilled - thanks KnurledNut!
I don't mind (too much) spending a decent amount on them (having used cheap/interchangeable ones before) but was wondering of i could get by with just the 45s rather than staight plus 90s (plus eventually in true GJ style 45s...)
L
littlebean
and thanks for the thread link vjquan - classic case of me looking but not seeing......
JradM
Alberta
Only you know how much use they'd see of course - but I bet you could get by with 45's for home use.
I used nothing but the Channellock interchangeable tip pliers for years and suffered no lasting psychological harm. I have a few more nowadays - picked up as I spotted deals. My skilz are also greater that they used to be, hence I might be deeper into a mechanical project that I would have attempted years ago, and options sometimes help.
The dedicated tip variety I have now are nicer to work with, but circlips themselves shouldn't challenge your pliers. If something is stuck due to corrosion or mechanical load - you need to solve that problem first and then the circlip should come out without too much fuss.
I think it would be a perfectly valid choice to try some 45s and only upgrade as required (or deals are spotted).
