Circuit question
bluedog225
Texas
I’m just starting to lay out the circuits for my little 25’x25’ shop. It will be powered by a victron inverter and LiFePO4 batteries.
Essentially, a small inverter air conditioner, several quad boxes spread around, and LED lighting.
I’m reality, I’ll only be using one or two of the quads at any one time. Small table saw, drill press, etc.
I’m thinking I need to keep the lighting on a separate circuit to avoid interference. Is that right? Thanks
mike93lx
Richmond, VA
Agreed, lighting is prudent to keep separate.
IMO, one 15a circuit for lighting with 14/2 and two 20a circuits for receptacles with 12/2. I would likely run a dedicated circuit for the a/c and 15a with 14/2 sounds fine for that.
bluedog225
Texas
Thanks. I’ll run the numbers before pulling anything.
It’s odd for me to think of 14 gauge for anything. I’m so used to everything being 12 minimum from the old days.
I guess stuff like lighting is that much more efficient these days.
mike93lx
Richmond, VA
Copper has gone up a lot and with led's, you can run a lot of lighting on a 15a circuit. Just keep it to 12a or less since it would be a constant load (assuming 3+ hr use at a time)
jeepxj
talks of going to 16g for lighting circuits with 10a breakers
jeepxj
dave*99
Coastal NJ
How old are those days? I see plenty of houses from the 60’s with 15A circuits. Old 14 Ga. Romex.
bluedog225
Texas
I guess I’ve been in my 50’s house for 30+ years. And older before.
An electrician opened one of my switches and saw a large bundle of soldered ground wires. “Not touching that.”
dave*99
Coastal NJ
My sons last house had BX with soldered connections wrapped in friction tape. I touched it. All of it. All gone now. I don’t know if it was 14 or 12. House was over 80 years old. I think it was built the day they first started using BX.
Mzungu
Yep, 1.5mm2 (16awg) on 10 amp breakers is pretty standard for lighting in a lot of Europe and Africa. Of course they are also using a 230/400 volt system. I banned 1.5mm2 cable on my site because I caught the guys using it for sockets and A/C units.
