Class B Venting
Best0186
Bismarck, ND
I am installing a 75,000 BTU Modine Hot Dawg heater. It will be vented vertically with double wall vent pipe, through the insulated attic (Blown-in fiberglass). Can I blow-in the fiberglass insulation and have it be in contact with the pipe?
Thanks
brewchief
No you need a 1" clearance, a piece of single wall pipe 2 sizes larger is an easy way to do it, 6 inch pioe for a 4 inch b vent.
Best0186
Bismarck, ND
Thanks, I was looking at the class B venting and it said 1" clearance from combustible materials. I didn't know if fiberglass blow-in insulation was a combustible.
Jackfre
N CA
Whenever you see a clearance you are best of to simply observe it. Splitting hairs with your insurance adjuster is not a winning hand
cadunkle
The few times I've done B vent through a ceiling I've used a firestop support and boxed out the framing to ensure clearance and no insulation can touch the vent. I nail flashing to the box so it's a noncombustible surface and extends above the level of insulation. Use a ceiling collar on the inside to cover gap in drywall or whatever ceiling finish material you use.
https://www.ameri-vent.com/products/fsp/firestop-support
