I’ll look for those. On yours, how true of a cut could you get?
On mine, even after leveling the bed, still get about a 5 tenths bulge near the chuck. The bed seems to have about a 6 thousands wear right about that area.
The other weird thing is the bed flats and V are not co-planar. So if I level using just the flats, it’s different than if I put the level on the cross slide. I’m using a Starrett 199, so 0.0005 per foot.
On this caliber of Lathe, .0005 is pretty good. Over what length and diameter are you getting that result?
I’ve seen some folks who have machines that are pretty worn, use their level on the carriage. That way the readings are relative to how the carriage is riding on the bed and taking the wear into account. Essentially, these guys are intentionally putting twist into the bed to combat wear.
While taking Richard King’s class, he demoed a method of twisting a lathe bed intentionally by turning a piece of material, measuring the taper, placing a magnetic base indicator on the toolpost,and the indicator on the workpiece, then adjusting the bed so the taper is worked out of the part. After that he would take a test cut, and make another adjustment with mag base on the toolpost and the indicator on the workpiece. There’s a little trial and error with this method, but he was able to fix a lathe that was cutting a .002” taper over 6” and got it down to around .0001” during this quick demo. (He could have gotten it perfect with a little more time)
