Clausing Drill Press
930dreamer
Amarillo,TX and Stinnett,TX
This is 3 phase, seller doesn't have 3 phase so I can't see it run. $700 is steep without seeing it run. Any idea what model this is?
EDIT: looks like a 20" 2276 with gear driven power feed
LXCam
Re: Clausing Drill Press on FB Marketplace
I wouldn't hesitate as long as everything turns freely. Even figuring in the cost of a VFD or a new motor you might be into it for under $1,100. And for that beauty would be a smoking deal.
Todd.Brock
Cincinnati
That makes me so jealous. I would leverage the 3 phase to your benefit. I may suggest taking a look at the Reeves drive set up to make sure it’s all in working order. That added to the cost of my Clausing by a few hundred in machining and parts costs. - kind of cool seeing AP_Mech working on my stuff though!!
930dreamer
Contact made with seller and the wife said go look at it....wait somethings going on here?
Todd.Brock
Cincinnati
Sweet- don’t ask questions. take the trailer!!
930dreamer
Loaded, any good advise to safely off load with a forklift.
Table looks nice
tarbellb
Oregon
Forgot about the vise, you were in the zone it seems!
Clausing's are so nice, did the wife hook you up?
Drop the head down, pick it up with two guys, then just walk it into place.
Final price....?
dutchgray
Dorset. England.
Table looks nice
Use one sling and lift the head of the drill from in front and behind the column with the middle of the sling over the fork, lower the head of the drill some if you need to get the height down.
930dreamer
Table cleaning, thinking about using these casters for a movable base?
cvairwerks
Within hearing distance of Texas Motor Speedway
I wouldn't...Have to make the base too big to not worry about flipping it when you hit something and stop suddenly. You've got probably 55% of the weight of the unit at the very top. If you need it mobile, then a metal pallet just big enough for a pallet jack to fit under it.
zkling
No arc of shame, nice!
They are nice drill presses, just hope you don't have any issues with the reeves drive.
tool_scrounge
Southern California
+1 on this. Much more stable to use a drill press without caster wheels.
930dreamer
3 Phase motor is 1hp so that makes this a 2273 model, what type of oil should I use in the power feed cup and what cup fills the site glass, I think there's 4-5 of them?
What would be a quality vise for this table? Thanks everyone!
GrayFlattop
Chicago
Nice score on the Clausing! I have a smaller one (15") of the same vintage (without the power feed) and it's given me great service in its second life for the past 20 years or so.
For a drill press vise, you can't go wrong with a Heinrich Grip-master. Not cheap new, but if you have the same luck in the used market, well worth it:
I've got a 4" model in the basement shop and a 6" in the garage/shop.
Cleave
Back Porch
Very nice.
I used to operate a (much cheaper) drill press on casters, got sick of them, took them off, never regretted it.
