Clean-up question … turpentine
Old tool guy
I'm using this product to apply a japan finish to some tools. The label says to use turpentine for clean-up. Actually it says to remove the varnish, I’m assuming that’s the same thing. I don’t have turpentine, tried using acetone, doesn’t come off my hands easily. Probably should have worn gloves. What else could i try?
Shiftless
East Bay SFO
I agree that nitrile gloves would have been a good idea. 😎
Now that that black goop is on your fingers, I suggest trying WD-40
BillK
Beautiful Southern Maryland
Turpentine ??? Paint thinner is basically the same thing but better if you have any of that.
pcmeiners
Turpentine warning.... Do not use this as a cleaner, if it gets on rags, saw dust or other materials which support combustion it can cause a spontaneous combustion fire, my mom's house nearly burn down due to drop cloths which had turpentine on them.
PCustoms
VT
Turpentine warning.... Do not use this as a cleaner, if it gets on rags, saw dust or other materials which support combustion it may can cause a spontaneous combustion fire, my mom's house nearly burn down due to drop cloths which had turpentine on them.
I believe the same would apply to the finish the op is using as well.
Or any oil-based stain/wipe product for that matter.
Shiftless
East Bay SFO
Old tool guy:
By now, you must have tried one of our suggestions. Did something work for you or ???
Hopefully you didn’t go with the gasoline suggestion and try it while standing near your water heater. 😱
545_days
Texas
I am a big fan of burning rags soaked with boiled linseed oil, varnish, etc. in a controlled manner before they can spontaneously combust in an uncontrolled manner.
Of course I also live somewhere where I can get away with that
PCustoms
VT
I sprayed some paint this morning thinned with acetone.
Had 3-4 rags and some "paint" left it a paper cup after cleanup, threw it in the pit and tossed a lit paper towel core at it.
larry4406
Northern Virginia
At the day job I’ve gotten tar on my hands.
I used the spray start on a rag to scrub it off my hands. Wasn’t the best solution, but all I had at the time. Stuff really dries out your skin and I’m sure not recommended.
O
Old tool guy
If your house is like mine, there are at least 18 tubes and pump bottles of hand lotion scattered about, variety of scents, all claiming to “fix” your deficient skin.
PCustoms
VT
Turp … yep, that’s what the label calls for.
Tried paint thinner, came right off.
As mentioned above I sprayed this morning. Was a good boy and wore my respirator. What I didn't do was clip the beard short like I normally do.
Been outside all morning, went in for some lunch and looked in the mirror.
Any tips for removing dried red Rust-Oleum from around your mouth? Hoping a shave and lava soap helps, otherwise I'm in for some awkward meetings tomorrow...
Stuart in MN
Minneapolis
Turpentine is fine to use, you just have to dispose of any rags properly. Burn them, or put them in a bucket of water, or lay them out on the ground where they can dry out safely.
Milton Shaw
I use WD 40 to remove oil base paint. Safe for hands and works great. Just spray a little on hands and wipe off with paper towels. The other reason is just about every home has some without having to buy some acetone or paint thinner.
O
Old tool guy
Hah. I have acetone, mineral spirits, brush cleaner, brake cleaner, engine degreaser, tsp and liquid sandpaper, but no wd-40.
