Cleaning around saw joints
klm123
Not sure if this is the right place to post this, but I have around 330 LF of saw cut control joints that I used Sikaflex SL as the filler. The slab itself was poured last March, and we just had our garage put up. I pressure washed the whole slab before the building went up, and I also vacuumed and cleaned out the joints, and then cleaned all of the edges with a wire brush. I then hit the joints one more time with the shop vac, and then installed backer rod 1/2" deep.
I was offered some help by a relative, and after all of that on my hands and knees, and up and down, I didn't hesitate to let him! He filled the joints high to let it level, but it did not level, and is still high. I am shaving it even with a razor, and that works good, but where the Sika overflowed to the outsides, it leaves a residue where it was before I shaved it. Kind of ugly.
What is the best way to clean this from both sides of the joint? Whatever it is, it sounds like I need to get my kneepads out again! Thanks.
astroracer
Mid_Michigan
Don't worry about it? Just my opinion but, once you get the garage up and working, filled with tools, work benches and cars, how much of this are you actually going to see? Just asking the question, sorry...
Mark
Richard Cranium
central Washington
use what ever the product recommends for clean up. With out a picture it is hard to understand how much of a mess your talking about. Or is it a ocd thing?
K
klm123
Sorry, I am trying to upload a photo, with no luck. Yes, it is an ocd thing, and the wife seems to think I am nit picking. It's just not the straight fine lines I want and it appears squiggly.They will probably wear off anyway. I have not found anything on the product, except other boating forums saying that sika has said once it cures there is no solvent to remove it. I will try to ignore it for now, but if I do feel that it needs addressing I will gladly try some of the suggestions that have been given. I guess I was kind of hoping someone had been through this and had the magic answer, but no sweat. Thanks.
