Thanks for the feedback. I am hesitant to get the Rust-Oleum clear epoxy. I read it has issues yellowing when exposed to sunlight so I wanted to get a better top coat product.
I went to get some Rexthane from Sherwin Williams today, he says it is too hot for the water-based epoxy coat we put down initially and it might cause the bottom layer to crack. He recommended Sherwin Williams Armorseal 1K which is a water based clear coat.
1) Not sure if I should put down Rexthane or this water-based Armorseal, confused.
2) Is there a window for when I can put down the clear over the original epoxy coat? It will be about a 2 week window before I can apply the clear coat
3) I've kept the floor clean and haven't walked on it, is there any prep I need to do since it will be two week in between the epoxy and clear coat applications?
Any help would be most appreciated, I dont want to ruin my garage floor
**By the way, I read your posts on
www.allgaragefloors.com, very informative stuff, if only I had read that before I bought the Rust-Oleum!!**
