DStewart
What kind of clear coat is everyone putting over the epoxy paint?
PaPaPie said:I used H & C Clear 23 sealer purchased at Sherwin Williams. It provides a nice glossy finish. I used the decorative flakes and slip resistant grit in with the epoxy so the final finish is not slippery.
PaPaPie said:However next time I will probably not add the slip resistant grit, I think the decorative flakes gives you enough grip.
GearHead_1 said:I went the other way and decided that the flakes (UCoatIt gives you alot) would be all the traction that I needed. When it's dry it's the perfect surface to feel under your feet. Feels like a freshy varnished gym floor. When it's wet, it's a different story. I was using a squeegee when cleaning mine out the other day and just about fell on my can twice. It made me wonder if I had made the right decision in not using the aluminum oxide grit.
Roadster said:Be VERY careful driving into the garage on a rainy day. If you come in too hot and hit the brakes hard, you might plow into the back wall of the garage.![]()
