Clocks spin differently way up north.Monday 2:42 am for question to Monday 6:23 pm (per my timezone settings) for “stumped” is two days? Did I miss something?
What's your budget?$
$64 with shipping![]()
Dont think I said they were "sketchy" They are all drums filled within I'd guess the last ~5 years. A few came with my property the others from a diesel shop.
Mostly concerned that there may be water or antifreeze.
I'm going to either pump them or tip them on the forktines and drain into totes.
Using it in a waste oil boiler im.setting up.
MMM. Sounds sketchy, based on your original post. Unless you have some pretty clear provenance on waste drums, smart move is treating it as I.D.L.H. (Immediately Dangerous to Life or Health). Advising you to do otherwise with no additional information would be negligent.Need a ~3ft long clear pipe to use as a dip tube in 55 gal drums to check contents. 1/2" I'd, or even smaller probably fine.
Ideas? Ideally Amazon or other free shipping places.
I have ~20 drums that are supposed to be used oil, but I want to sample to make sure before pumping into a tank.
I can't erase it for some reason and somehow it wandered off that I'm testing nuclear wastes and dioxins or some crazyness.I have the distinct idea that @Sumboodie wants us to disregard this thread.
I have about 12ft for testing my **** tank that I forgot about.Smidge out there but if you've got a decent part supplier nearby that does water cooling bits they'll probably have 3ft lengths of clear hard tubing
