DavidB
hey david,heres what i have.i mic'd the washer and my battery died on the mic before i could read it.but what i did was match the gap with something you could copy.i used two regular razor blades stacked.it's the same snuff fit as the washer was without crushing it.closest i can get for ya,maybe you can put the two blades together and mic them to see what you have.right now all my clearences are good except i have to find a way to stop the bolt from turning,when you turn the knob.check the pics
Thanks for the pics. The parts diagrams call for another nut to be placed on the bolt on the pulley side of the front casting. Since the front casting is threaded for the bolt as well you can tighten the nut down so the bolt doesn't rotate.
