Good looking table, Ovrrdrive!
Is there anyway you could post a few pics of how the gear rails attach under the CRS?
Thanks in advance!
3M Tape.
Thanks in advance!
As mentioned they're mounted with the 3M VHB tape. Just clean everything with acetone or alcohol first and clamp it for 24 hours. It's really strong stuff.
Really? DS tape? That's it?
It can handle the directional changes?
Everything around here made out of foam or rubber seems to break down after a bit when exposed to temperature changes or humidity.
Yep but they don't tell you the rail is 4' pieces and you weld it together.
It cost us $216 for materials, and were able to get it broke for free. We are using 6' x 12' x 10 gauge sheet for a finished table size of 64" x 126" x 4" deep. We will add a drain pipe with ball valve and water hose fitting, as well.
The water table makes a world of difference on cutting down smoke and slag. Practically eliminates the smoke when the water is filled up to the bottom of the sheet of metal. If you do go with a water table, make sure to use a rust inhibitor water treatment, as the water gets nasty quick. Also, be careful cutting certain aluminum alloys over water, as they can create a hydrogen explosion.
If it's not too late I strongly suggest putting the slats 1/2" or so down below the top sides. Wish I did I will be adding angle to mine someday.![]()
I think the way that we are planning on putting the slats, we should have a 1/2" or so of clearance, but may I ask why you suggest that? Just curious.
If you fill to the bottom of the plate to use the advantage of the water for filtering, the air moves the water over the top, all over the table, electronics that are exposed; should not be any! and the floor. it makes a mess and it would be a very simple thing to do if done the first time, not so easy after the slats are set.![]()
Which mount did you order from velox for the pm65's machine torch. Looks like they have two sizes. I ordered a pm65 last night. I went with the dual machine and hand torch combo. I need to read your thread more to check out your thc. I assume that is a velox za650p z axis too?
Hi ovrrdrive. Can you post a picture of the back of your Gantry? I'm building mine now (4'x8') and curious how others have ran the track.
