TractorTherapy
I bought a refurbished Coats 1400 balancer off the internet. I've only played with it a couple of days now, but I'm having a hard time getting consistent results. I suspect it is my fault, not the machines. It came with 4 cones and a plastic quick hub nut.
1.) I have 4 new steel 16" 5 lug trailer tires and wheels that I thought would be a good place to start to play around/learn how to use the machine. I'm having the hardest time getting those mounted on the machine! They fit 2 of the cones, but I can't find the "technique" to mount them so that they are on there without wobble. My best/straightest mounts were by getting the tire on, spinning it towards me and then bumping the hub nut several times...1 of 5 attempts got the tire on "mostly" straight.
These cones aren't the ones that Coats sells with this machine...new, it would have come with a set of cones that are beveled in both directions vs mine which are beveled in one direction. The cones/plastic hub that came with my machine look like a set I could order from Amazon for about $100. I assume that the dual beveled cones have a shallower angle to them and perhaps this would help center and seat the wheel. But, is that my problem? Is it the tool, or operator technique?
2.) I tried with a factory mounted/balanced 18" AL wheel/tire off my car, which I have no reason to believe to be unbalanced, but it is approaching the tire wear marker. One of the 4 cones, fit a bevel on the inside of that wheel and it mounted up fairly easy. It indicated to add .5/.5. I mounted and unmounted this tire many times and it didn't always say .5/.5, but that was the median reading of about 15 attempts. I'm assuming that this is again operator technique, not machine error?
3.) Calibration: I have not calibrated the machine since it arrived by freight from across the country. I was initially hoping to use one of my new trailer tire/wheels as a calibration wheel by having it balanced at the shop up the street, but I'm hesitant to do so since I can't even mount it straight. The manual doesn't indicate what size/type of tire to use for calibration...I was thinking of getting just a used AL wheel at the junk yard with a small hole and a new/cheap tire for it. Thoughts?
Thanks!
Thanks!
