blazentrout
Im currently pulling wire to get ready for my 200 amp upgrade on my breaker box and i have a question what i need to do for my well pump wiring running from the ceiling to the pressure switch.
I an replacing the well wiring from the breaker box to the pressure switch do to the fact it is cloth covered with no ground that feeds into a single place glass fuse box then to the pressure switch with a piece of 14ga romex that appears to have no grounds on the advice of one of the electrician that came out to give me an estimate. He said better to be safe than sorry and if you run the wire, i'll hook it up/swap it for you nc and it will save both of use grief from the inspector.
As much as i would like to secure the new 10/3wg romex to the pipe running down pressure tank and switch like it currently is, i dont think that will fly code wise. since its approx 36" from the ceiling i think i can code wise just sleeve the wires in some 3/4" conduit and run them up to the height of the ceiling joist for protection. then just secure the top of the conduit to a cross runner to keep them from moving and call it a day. any suggestions/recommendations/comments/ect. thanks.
A side note the basement is only 68" tall to the bottom of the joists and when i do the new hot water heater and water softener i will be moving the tank to a better spot. And the orange wire in the upper left corner is the new pump feed, it just sitting there waiting for me to finish the job.
because i had an ID-10T moment and had 10/3wg on my brain when i went and bought the wire and i cant return it now do to it being a cut piece off a roll. So instead of spending another $50 for 10/2wg i just figured i would use what i had instead of having it hang out for ever. you are correct running it is going to **** but tis life.
