Cruzan80
I have a set of collets that came in a pile.of stuff, and no luck trying to identify them. Top flat of cone is about 3/4" across, bottom of cone is 1" across, cone is about 13/16 with last 1/8" vertical (no taper). The ones I have run from 3/8-3/4, by 32, with two 64s in as well (pic is missing 7/16, but think it is on the workbench). Bottom of collet is between 1/8-1/4" thicker than the marking (larger collets have a thinner lower wall).
Last picture is of assorted stuff in the same boxes. Boxes are simply fiberboard woth brown taped edges, no markings. One tube is marked Johnson EM 48, both tubes only accept the 1/2" collet.
All of this measuringcwas done slap-dash with a tape measure, so if you have an idea but the numbers are slightly off, happy to reverify with calipers/micrometer.
