Common Mistakes
Lucid Moments
Gainesville, Ga
So I looked around and didn't see many stickied threads too look through for common mistakes. I am in the process of building my first shop. Main purpose is in support of my road racing addiction. Shop will be 50 X 60 and my current plan is to have two, two post lifts in it. Three roll up doors across the front with on on the rear wall to allow for roll through parking of my tow rig (22' enclosed trailer and tow vehicle). All I have for current plan is to allow 14' from outside wall for tow rig, then lift one, 5ft space from lift to lift, then lift two which should allow about 17' X 50' for open shop space. Lifts to be spaced 12' from back wall to allow for room for work table and tool box in front of them. That is all I have at the moment.
A couple of things I have considered and decided I can either put in later, or are not cost effective. A system of receivers for dead men in the slab for pulling a car straight can be put in later. An overhead lift system would be nice but is gross overkill.
I have been around a number of different shops and have put some thought into this, but am looking for the things I haven't thought of. What do you wish you had considered when building the shop?
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
Welcome to the GJ.
May I suggest you update your profile with a better location as in future you may find that helps. Specially given this is a very global forum. Often you will find subjects may get different answers depending on locations and regulations.
I am sure you will find many helpfull ideas on this forum and yes some of us make mistakes when we build but many of us share some great ideas on this forum.
