Common Venting
abwehrly42
Tennessee
I would like to add a natural gas heater to my attached garage. I've done a little research and learned the term common venting. Is it possible for the heater to share a vent with my water heater?
gmcgeo
The vent must be separate from the furnace
Now you can vent both together if they are both 80+ efficient and going into a chimney, however check your local code on this
Gizzi
Common venting won't work with what you currently have. Is there a particular reason you want it common vented?
A
abwehrly42
Tennessee
Thanks for the information. I was hoping to combine vents to minimize the number of penetrations in my roof.
gmcgeo
as long as its a power vented, OR exhaust fan is attached to the b vent pipe.
Jackfre
N CA
That is a 3” vent and no your cannot add anything to it. Your best bet is to look at Direct Vent Wall Furnaces. You then have the option for side wall venting. I use Rinnai’s
gmcgeo
he can get a power vented water heater? that is a side wall vented application also. tankless water heater is what you are talking about that you have?
