chaingang
Well in my case it may be just a barn door. After reading and even responding to several threads here about carriage house doors I finally tackled mine. I had mentioned in another thread I was contemplating building mine inside the opening and this is what I did. They may not be as intricate as some of you need for HOA or Historical approval but they could very easily be dressed up with a lot of detail I would think. My shop is going the rustic southern barn route so they fit the bill nicely. They are not complete as I need to add some trim at the edges where the T&G overlaps the frame, insulation and interior skin. I also have a couple of boards still atached to the right door so that I can hold them closed. Not decided on the interior latches yet. They where framed in place with 3/8 spacers installed around the perimeter. I screwed through the outside 2x4's to hold it in place then framed them up as normal. I left enough gap between the center posts so that I can add the trim pieces and still allow them to swing past each other. I attached the hinges, removed the perimeter screws and then cut them loose. Everything went as planned and no sagging at all when I made the cut. Thanks to Sundowner for the hinge info.
One down and one to go.
