will gilmore
- Joined
- Oct 11, 2009
- Messages
- 65
I have a IR 7.5hp 80 gal two stage compressor. I've been running a cheap filter/regulator combo but I'm getting ready to run some air lines and I figure this is a good time to install a better set up.
Here are the components I'm considering:
Air cooler: I have a some 3/4" black iron pipe, tees, and ball valves so I could make a series of up and down lengths with drains at the bottom to cool the air.
Desiccant drier: built or bought (will be added later)
Water separator / filter
Regulator
I'm thinking it will go like this:
Compressor
Flexible line
Black iron air cooler
Desiccant drier maybe with output filter in case the desiccant breaks down)
Large diameter gauge for tank pressure
Regulator
Large diameter gauge for line pressure
Thoughts on that order?
Worth building the pipe air cooler?
Regulator
Compressor
Flexible line
Regulator
