AtlasRearden
Wondering if there are any compressed air experts out there that can offer some guidance.
Before my house was drywalled, I installed 1/2" type L copper pipe in the walls down to my basement where I'm putting a 230v 5 hp Puma (TE-5040V) with magnetic starter. I have 230v running into the garage where there will be a switch on the wall.
Here's my copper pipe sticking out of the wall in the garage:
My plan is to run the copper line from where I have it stubbed out to a mounting block on the wall that will hold the regulator set that I have:
As you can see, I have two brass couplers. Here's a close up of the couplers:
My plan is to mount the regulator unit between those two couplers so it could later be removed for service/replacement if needed. From there, I would take a soft line up to my hose reel seen in the first pic. I would also have a small drop under the reel with a ball valve to release the pressure, catch any backflowed moisture, or whatever. Here's a rudimentary diagram:
A few questions:
1. Does this seem like a reasonable approach?
2. Are there any preferred types of ball valves to be used for compressed air? Any brands better than others (I prefer made in U.S.A. wherever possible).
3. I was planning to solder male copper threads onto my pipe wherever there's a ball valve and then get female threaded brass ball valves. Is this the best practice?
A few questions:
