Compression - Show Off Your Compressor
Chuck79
I replaced the springs and the plates (upper right corner) it was the only thing that came with the valve kit I ordered. Everything else I refurbished, purchased the retaining rings local.
The head was packed with steel mesh from the oil bath filter.
I chose to make a tool from an old socket to remove the valves instead of dishing out $150 for the proper tool. The valves took some work to remove and clean up.
Durka
Howell, MI
1967...Looks like it was a lot of work bringing that one back to life. I take it the tank wasn't in too bad of shape. That must of been cool firing that thing up after you were through. :rocker:
malibu101
Walnutport PA
Just got this big guy repaired and running.
Well, it does run perfectly fine but it's not running here since it is 3 phase and I don't have 3 phase.
80 gallon 5HP with R-15B compressor
Jerm
Nebraska
Here are the compressor that I have that iam working with.
7.5hp 80 Gallon Ingersoll I picked up when the place I worked for closed. Currently the one in use. (sold)
5hp 100 gallon Wayne I got off Ebay needed a new contactor, will have to do more work to it, would like to do a rebuild.
7.5hp 80 gallon Quincy 244-16 that I picked up cause it was setting in the scrap pile at a service shop cause they didnt want to buy a motor. They bought a new compressor insted. I want to do a comlplete rebuild and paint on it.
Jerm
Nebraska
I will look and see if there is a part number on it when I get home. It was on there when I got the compressor. I tried it with if off and it does help, but once I get my enclosure built I will probably do a remote intake to get it out of the same air as the rest of the unit.
GYPSY400
Naughton Ontario
Here's my bad boy! I just picked it up Friday, and now I'm out of town working so it's not installed yet
It is a DV Systems ( formally known as Devilbliss). I5-5580. 80 gallon 2 stage
Jerm
Nebraska
That DV is a good looking compressor, nice that it has a made in Canada tag on it and not one from China.
TorqueBangers
My 60 Gal Campbell 6 HP strong as ever next to an 80 Gal 8 HP husky some guy literally traded me for a snap on cordless impact. Sold it the next day doubled my money! :rocker:
GlenC
Downey, CA
I plan to upgrade my old Craftsman compressor with a 10CFM 3HP Atlas Copco compressor pump... getting it w/o the motor (3 phase) may convert to belt drive... cheaper than buying a face mount 3-hp motor
GlenC
Downey, CA
It's been way too long since I've been able to work in the garage!!! My compressor can use some cleaning...
canuckian
East coast of Canaaada
Hockey pucks. If you can find any :lol_hitti
Anyhow, good to see a Canadian buying a Canadian built unit. Unlike another patriot on this page. :eyecrazy:
guessing you're referring to me ? I actually looked into the DV units but the local supplier didn't seem too interested in making a sale. I'm as Canadian as the next guy :canada: but there's only a certain amount of effort I'll go through to give someone my money .
Rossco
Great White North
Yeah am just pulling ya leg. Shame the dealer didnt entertain you.
Probably cost more to ship a DV across Canada than the Quincy cost. :lol:
Shame thou as a 447 would :bigun2: that blue elephant.
canuckian
that was another thing that sealed the deal on the Quincy for me. Didn't have to pay a cent for shipping (normally it's $700+ direct from the factory). Dealer piggybacked it onto a stock/larger order plus gave me a discount on the unit itself.
Can't argue on the 447 vs. qr325 as I don't know a lot about the DV units (research stopped when the dealer snubbed me) but they sure do look like great machines. If the Husky I have in the attached garage ever dies I'll likely look a little harder at their SDI line.
b-body-bob
Almost Heaven
Thanks for the tip! any volunteers to help me lift that big *****??
A cherry picker would be your friend. Once it's off the pallet you should be able to put the pucks under it one at a time. Just find someone you don't particularly like (I kid, I kid) to stand on the other side to keep it from getting away from you when you tip it up.
Yea, a lot of people do. Curious how much quieter they are when sitting on rubber pads..if any ?
Mine's pretty quiet, relatively speaking. I considered putting pucks or insulators under it, but never got around to it.
Durka
Howell, MI
That Champ (gardner denver) would be quieter than my 2stage IR, in comparison. Well , it should be anyway, - even though the IR is on rubbers/+cork.
That DV looks well built GYPSY
GYPSY400
Naughton Ontario
For now im going to keep it on the pallet. . Its in an insulated room anyhow.. so no room for a cherry picker.
Sent from my SGH-I747M using Tapatalk
GYPSY400
Naughton Ontario
I travelled to Barrie from Sudbury to pick it up. . My local dealer wanted $2200 before tax.. the dealer in Barrie sold it to me for $1885 taxes in! And the bonus is I used my company truck so all I paid was time... 7 hours round trip.
It does seem like a well built unit.. the motor is a Leeson, and I dont see any "made in china" on the compressor head.. also the welding on the tank looks stellar. It also came with a mag starter ( square D) and a ball valve for the air output and water drain.
shopnut
Florida
Just your run of the mill Campbell Hausfeld 6hp/60gal here. I bought it second hand and it seems to be in decent shape.
I'm about halfway through the installation and the story starts here if you're interested: Linky
In an effort to gain some usable space below, I'm getting it up off the floor and it will be enclosed in a ventilated cabinet when I'm all done.
Current status is the addition of some special valving and soon the automatic drain system:
Gauges, regulator, and hour meter will be located on a control panel down where I can reach it easier.
I will give a quick update when it's all finished.
