Compression - Show Off Your Compressor
EOC_Jason
Bentonville, AR
Someone help me. I tried searching for compressors being outside in the cold weather. Looking for AC's that would go inside a shed protected from elements, but not cold NY/LI weather. Most likely not advisable but what the hey.
Any posts/search terms to use to find such topics?
Been tons of posts on the matter... Best advise is to run synthetic compressor oil, that's about all that is required...
UglySign
Yes im sure there has. Have you tried searching?
LOL... I mean I did but alot has lil mention and most
of the time I get diverted looking at diff garages that
I forget what I was looking for. Besides, it's sometimes
within the topics I mentioned.
I'll have to find some time this weekend.
Thansk!
Found one here: https://www.garagejournal.com/forum/showthread.php?t=379786&highlight=compressor+winter that EocJason mentions
Ole Slewfoot
Freedom, CA
This was in the rafters when my friend bought her garage.
redmondjp
Redmond, WA
fixed!
mechanical/adhesive fastener is still the preferred choice in supercars and airplanes. :beer:
Yeah, the rivets are just fine! It's those two welds on the RH end that are, well, interesting. But at the thickness of that tank, and the low pressure (probably shuts off below 100psi, maybe even at 80), I wouldn't be too worried about it.
It looks like it's been restored! That's a real barn-find compressor, that one is. Complete with vintage warning sign.
jetlag
Centralia,Wa
picked up an older Devilbiss 5hp, 80 gallon compressor with the 44643 (predecessor to the 247) pump. Gov't surplus auction, came to about 250 after auction fees. Only visible damage is the squirrel cage, looks like it got beat up during a move. I'll clean it up, change the oil and belts, and do any other necessary maintenance, then plumb it in. My shop is slowly coming together.
Jim Johnstone
Brantford, Ontario
that should last you forever and a year.
Sent from my SM-G920W8 using Tapatalk
jetlag
Centralia,Wa
spent an hour or so with this old Devilbiss Tap-5050 this afternoon. First task is just to clean decades of grease and dirt off it
prosparky
I got my new compressor hooked up (finally). It’s a Quincy QT-54. I used a 1/2” hydraulic hose from the compressor to the copper line. Copper tubing is 1/2” Type “L” soldered with silver bearing solder. The regulator is a Parker 06E24B18AC with a Winters PFQ gauge. The compressor is modified with a Square D pressure switch, and a Winters PFQ liquid filled gauge. The power is fed from a 40 amp breaker and #8 wire. The hose reel is a Reelcraft 50’ x 3/8”. I tried to buy “Made in USA where I could. Overall, I’m very pleased with this setup. The biggest issue I had was air leaks from the compressor itself, which were fixed under warranty. Quincy’s choice of pressure switch on this unit is not ideal. It’s really too small to terminate the supply wiring without cramming everything in the housing. Otherwise, it’s an awesome compressor. Well worth the cost.
TM98
Can I see a picture of how you have the compressor tied to the copper lines.
prosparky
Sure-
Nothing too fancy, just a 1/2” hydraulic hose.
Dan in Pasadena
Pasadena, CA
Maybe I am missing it, but why is both copper AND black iron being used? Why not just one or the other?
The setup looks very nice. I’ve even saved the photo to mimic stalling my hose reel and ater trap/regulator, just wondering why and how you dealt with the electrolysis from using dissimilar metals issue?
UglySign
Hey im back.... my QT5 delivers Monday the 9th.
Have a Q because of all the ideas you see during the search while waiting.
This video where the guy puts a Kenworth Air condenser on the wall.
(T2000 condenser, equivalent of Kenworth 486-684-5008)
Is this possible for the QT-5 and has anyone have a setup like so?
Wouldn't it be best that there's less heat esp in the tank?
Is anyone using a high temp & pressure hose from the cylinder head?
Looking to keep things cooler eventually as well as dryer air.
Next Q: Or is it better to just get a refrigerated air dryer and call it George?
Searching is a boon as some of the posts have 20k+ replies.
Thanks :scared:
pcmeiners
"Next Q: Or is it better to just get a refrigerated air dryer and call it George?"
It is better if you enjoy higher electric bills for no reason. A coil cooler uses little, if any, energy for cooling verses a refrig dryer. Using both will give you super dry air at the least cost. Hayden DB 1260 or 1290 are good cooler to use.
What so terrible about searching for...... compressed air cooler..... or similar words, this has been answered 20k times
BigNuge
Live Free or Die
Well, looks like I’m going to be picking this beast up. It’s an industrial duplex compressor with twin Quincy 340 pumps and electronic alternator, mounted on a 200ish gallon tank.
I’m either gonna pick up an inverter to use it at my shop, or clean it up and flip it. Not sure which way I’m gonna go, it’s awfully big for my needs. My 80 gallon IR suits me just fine and is a fraction of the size.
Anyone have experience with these big pumps?
redmondjp
Redmond, WA
Wowee! When you say picking up, what do you have to lift that thing with?
Beast is right, as it weighs probably close to, lessee here (opening up the QR25 brochure), assuming that is a model FF340 with twin 7.5HP motors and a 200 gallon tank, you're at 2250 lbs. (1675 lbs. with 120 gallon tank).
With both pumps spinning, FIFTY-TWO ACFM @ 175psi!!! That will easily run two sandblasting cabinets at the same time.
BigNuge
Live Free or Die
Lol, yeah it’s heavy for sure!! That’s sort of the reason for me thinking of flipping it. If I keep it I’d set it at the far end of my storage area and that’s that. I certainly wouldn’t be moving it around!!
Bigblockyeti
Upstate, SC
Here's my Quincy 240 that I've pieced together from several different sources, I still need to put the motor started together and figure out where I want it as I certainly don't want to move it more than once!
Trey T
Houston, TX
That's a heavy duty single stage beast ... for light duty jobs (home or even auto shop) push it to 120psi @ 900rpm.
Yeah you certainly don't want to move that heavy-*** beast around. How did you managed to get the ~300lbs pump onto the tank?
Bigblockyeti
Upstate, SC
With an 80 gallon tank, setting the cutout pressure at 115-125psi should be plenty for what I need to do in my shop. I picked the pump up and set it on the tank platform, it's heavy but I don't think it's 300lbs.
Trey T
Houston, TX
I forgot to mention that all QR-25 single stage pump, except for 210, has a design pressure output limit of 100psi. You should push it to 120psi and it'll be fine
These pump are typically seen in industrial use, such as manufacturing, refinery, or oil field for continuous use (24/7/365days)- the beast of all beast air pump
Richard D
Texas City, between Houston and Galveston
Pictures. I have some somewhere of it finished.
86turbodsl
I did something different with my recently-aquired DeVilbiss 342. I mounted the compressor/motor inside and the tank outside. It is quiet and I actually enjoy hearing it run.
Exactly what I want to do. You in a cold climate?
Sent from my LG-TP450 using Tapatalk
prosparky
Thanks. I used what fittings I had at the time. I’ll change it to all copper sometime soon.
Smiles79
Northwest Missouri
Just picked up my first compressor at an auction this past Saturday! Says it's a 3.5 hp 20 gallon that will do 6.4 cfm at 90 psi. Haven't used it for much other than blowing stuff off and filling tires, but for $130 I was happy.
Changed the oil and cleaned it up a bit since this picture, and fabbed up a hook to mount on my workbench for the air hose.09edc167b72754e4ce0ea16ee023ef56.jpg
Sent from my Pixel using Tapatalk
UglySign
Possible for the following. QT-54 / 60 gal.
Looking to get a High Temp/Pres SS Braided Hose
made for it. Hose going to Hayden 1260. Im a lil
patinaed going the copper tube method.
Thx
TRWham
East Cobb County, Georgia
Thx
What problem are you trying to solve? They use copper tube for a reason- it serves as an aftercooler prior to the air entering the tank.
UglySign
Thanks Wham, I appreciate your concerns but this is what I'd like to do.
Others have done it, so..... :shocking:
Yes EOC... 3/8
