jack bacon
I received a Puma 6060V compressor for Christmas uses a 15A 220V motor. I already had a 40A circuit running to the attached garage using #8 wire. I don't use a welder so I changed the breaker in the panel to 20A double pole 220V breaker using the # 8 Wire into a disconnect box in the garage and from there #10 wire to the compressor. The compressor works fine except the seperate 20A 120V receptacle circuit 20 A breaker trips.
Both of these circuits are run thru the same conduit a total of about 20 feet out of the house and then back into the garage. Can the 220V line induce into the 120V and trip the breaker?
Would it be be better to just install a sub panel in the garage and run the two circuits of the subpanel?
Thanks!
Jack
Thanks!
Jack
