Trey T
Bob: Did you paint the inside of the crankcase? I have seen a few ppl just prime it (red, rust converter stuff) but no other coat of paint.
GapFast said:I'm wondering the same thing. I just painted the crankcase today actually.
The industry standard primer for internal is called Glyptal. I just found out and it's not the rust preventer primer sold at local store
I've also read of people using rustoleum #769.
I wish I would have thought about this before I painted the outside!! Oh well. Still haven't decided what I will use yet of anything
I wouldn't sweat it. Unless you hot tanked or baked the casting there's so much oil in the pores of the iron that paint wouldn't likely stick anyway.
Hot tanking and painting a compressor pump goes beyond what I could imagine. I suppose if the manufacturer did it. That pick of the milkshake looks like there was water introduced (sat outside?) maybe?
I tolt the machine shop to clean it they might have hot tanked it.
Before I gave it to them I blasted it
What all else is the machine shop doing to block of the compressor??[
Grind crank. Hone cylinders. Only thing they done to crankcase is clean. How? Not sure. I wasn't impressed on how it came back.
I was wondering the same thing CNG Saves. What all is the machine shop doing to the case? Just cleaning it? Honing the cylinders. I never thought about taking a compressor pump to a machine shop. B
Stroker crank![]()
)Last time I checked, a new Curtis CA series 5hp, single phase, 80 gal with intercooler was north of $3000.Curious what a new FS Curtis 5 HP / 80 gallon would even run (without all the improvements added) . . . maybe $1,500 to $2,000 or more??
... I have run it from empty to 175 psi cut-out and the cooling does work...
