compressor drain ball valve
PoorOwner
CA
I was wondeirng what kind of elbow do you guys use (brass, galvanized etc) and I do you just force the next turn so that it points the exact direction you want? I hope it does not snap off.
Teflon tape or use rector seal 5?
Norton155
Niles IL
I used a galvanized elbow and short piece of pipe with a brass ball valve. I did not tighten it as much as I could have, just used plenty of teflon tape. No leeks since I have done it about a month ago. I can probably get it around one or two more times but I just left it sticking out the way I needed it to go.
eschoendorff
Same here. Cheap, easy and I haven't had to worry abut it.
Lyaec350
somewhere...
Use brass, the incremental cost over galv is like $1.00 for the entire set of parts you'll need and you can be confident that it will never rust.
You'll need a 1/4" x 1/4" street elbow, 2 short straight sections (length dependent on your compressor) a 1/4" ball valve and a 1/4" by 1/4" standard elbow.
From the compressor:
Street elbow -> ****** -> ball valve -> ****** -> standard elbow
The last elbow keeps the water from shooting 2-3 feet out across your shop and instead directs it straight down. If you have a nearby floor drain I suppose you could put some plastic tubing over the last ****** and then direct the water whereever you wish.
eschoendorff
Yeah, but it's funnier if the water shoots across the garage! :spit:
Charles (in GA)
50 mi south of Atlanta
I used galvanize, no issues with it. If I have problems several years down the road I'll deal with it.
Charles
nissan_crawler
Wichita, KS
I vote brass. If you need another 1/2 turn, and it seems to get tight, just run a pipe die up it a little bit more and try again. It's harder to get another half turn on 1/8" pipe than 1" or something.
P
PoorOwner
CA
I went to Lowes and all the galvinized stuff starts at 3/8"
I can't seem to find the 1/4" stuff?
If I get the 1/4" brass street elbow is very compact and I am hoping it's not too high, actually, also can't find a 1/4" ball valve..
rsanter
visalia ca
I have used both brass and galv depending on what I have had on hand
I like using the liquid teflon stuff for this as I can leave it not so tight or tight depending on the position I need it to be and it will still seal up
bob
Charles (in GA)
The Lowes here has an excellent selection of plumbing fittings and valves. The brass stuff will be on a board/drawers, bagged up, and not in open bins. Valves should be right with the rest of the bronze ball valves.
Charles
P
PoorOwner
CA
OK I am done, it took 2 trips to the store but it was worth the time doing this
I used all brass, the longest ****** is 6" so I have to couple another 4".. then adapt to 3/8" and used 600 PSI WAG brass valve... (can't find 1/4" valve!!) the thing with brass is that it cost like $30..
I got lucky with the direction, the first try didn't point to the right direction, but I removed some of the crud stuck in the threads I am able to get it tight and point forward. (using a die would also work really well but I don't have a 1/4 pipe die)
Lyaec350
somewhere...
Where did you get your stuff? I got my 3 *******, coupler, 2 elbows and ball valve for <$15 at Menards...
Another way to line the fittings up is to add a bit more tape if they don't go where you want the first time... usually the added thickness is enough that it will keep the seal while torqued to a lower setting.
P
PoorOwner
CA
I got mine at Lowes.. Valve is $6 and ****** is $8, then other little fittings and adapter $2-4
If you got yours few years ago I understand but the brass and copper fittings prices raised way high these 2 years. Also these are individually bagged nicely machined fittings made by "wells".. except the valve made in China but still look OK.
