I was farting around on the internet the other day and ran into a pretty smart outdoor compressor enclosure that utilizes a smart muffler of sorts.
You can see the details ...
That's a pretty elaborate set up for that baby compressor. Nice though. Hopefully no water ever gets in there and he drains it frequently.
That is what I was thinking too. Would not work for me for sure with our humidity. I don't think that is a pancake. Seeing how deep he dug it it is probably a vertical 30 gallon or so. Makes more sense about the size and noise he described. I would hate to lift that in and out, especially with about 10 gallons of water in the tank.
That oiless compressor is doomed to death by overheating. That is if the light switch he's feeding it from doesn't burn the house down first. If he lives in a climate that has winter, the filter dehydrator will burst the bowl the frost time it freezes, too. I also can't believe he spent all that money and time for that little compressor.
Tommy
Tommy
For the amount spent on that hole, he could have bought a 2 stage with a low RPM pump that puuuurs.
Here is mine that function as a pegboard:
I worked in a shop that had a compressor in an un-ventilated closet! I mean 4 by 4 closet! Took about ten yrs for it to finally have an issue. And it could have more from neglected oil changes than heat.
Did you look at your compressor? On my antique craftsman the main sheave has a fan built into the spokes. I don't think you'll have a problem, plenty of air circulating around it.
Needs a remote tank drain.
What about one of these off the shelf cabinets? Anyone have experience with these?
http://www.sears.com/california-air...iL9TQZ-1myd8Ye46RVht-BoCSkLw_wcB&gclsrc=aw.ds
And another thing, why go to all the trouble to relocate the 30 gallon into the ground? That tank doesn't make any noise. Just remove the noise-maker motor from the top and relocate it.
I've often wondered why more people don't do that.
Those guys at California Air Tools (CAT) appear to have problem with understanding that words mean things.
The description reads," The CALIFORNIA AIR TOOLS SPC03 Air Compressor Sound Proof Cabinet is designed to reduce the noise from an air compressors by at least 40%."
In my book 40% less noise is not "sound proof".
