65Stang
I have been planning on upgrading my current 21 gallon, 5 cfm/90 psi compressor to a 2 stage 60 gallon, 15.5 cfm/90 psi compressor in order to accomodate my new sand blaster, air tools (grinder, sander, etc.) and future painting activities. Have not yet picked up the new compressor, hoping for a craigslist deal, but have not seen any for quite some time. Would like more cfm, but definitely cannot lay out more $$$.
So, still using my 21g compressor and was using it last night, just using a small ratchet doing some minor work, compressor is in a small enclosure outside the shop. Not really paying attention working away. Picked up the ratchet and hear a small leak coming from where the quick disconnect screws onto the hose. Strange. So, go ahead and use the ratchet and HOLY S%*T!!! The dang thing about ripped the nut right off the bolt is was going so fast, heck of a lot of pressure behind it. Took the other three nuts off and stopped. Waited. Waited. Oh ****, the compressor is still running. I quickly unplug it. It was dark, late, raining, etc., so I didn't go see what the overall pressure was, but went ahead and released the pressure through the line and there was a LOT. Lucky a hose or connection didn't blow.
So, not sure I will be selling the 21g compressor. On the new compressor, was planning on using an oil cooler between the pump/motor and the tank in order to cool the air. Use water traps after that and at the equipment, etc. I am thinking that I could somehow utilize the 21g tank in conjunction with the new compressor to help cool the air in place of spending the $$$ on oil cooler, lines, etc., but wanted to see what my options were from the folks here.
I had thought putting the 21g tank between the new compressor pump (two stage) and the new tank or after the new tank or...
Thanks
Thanks
