My small, twin-tank emglo compressor seems to be dead, but I'd like to attempt fixing it since I have no $ for a new one.
A couple weeks ago I turned it on and it quickly started pumping very slow and within a few seconds it slowed down completely, then was silent. When I tried to turn it back on, nothing. I checked the volts at the connections to confirm that the switch was functioning, and it does deliver the proper voltage once the switch is turned - but makes no sound at all when turned on.
This may be completely unrelated, but there were two other problems present before, which I'll mention just in case:
1. The cut off switch did not work, so I would have to turn it on and wait for it to get up to the pressure needed, then turn it off before the safety valve would open
2. The pressure gauge (not the gauge at the regulator) on the top of the upper tank was always stuck at 120psi and never would go up or down from that
In any case, I still managed to get by using it without repairing those issues, until now.
Thanks for any advice that you may have!
