Just picked up my ir 2340l5 today. Was a return. They said his reason was it was not as described.. Powered it up and found it is leaking at the pressure switch. There is a smaller copper line that connects to it. The fitting that the copper line goes in is leaking. I pulled that out. Found a nylon sleeve in there not sure if I just need a new one or if there is a special orientation for that insert.
Tried to find the part on an ir parts diagram with no luck. There was some rtv there so the op tried to fix it I think
Thanks,
Brian
Thanks,
Brian
