Compressor motor...
pault28
Westchester, IL
Is it normal for a compressor motor to have a lower gauge wire from the motor to the pressure switch? Mine has about 18" of 12awg wire between the motor and pressure switch though the motor says it draws 21A. I thought 12 was only good to 20A. This is the motor...
930dreamer
Amarillo,TX and Stinnett,TX
I know my Champion is wired with smaller gauge wire also, the wire conduit is very small to the pressure switch. The motor may draw 21 amps but I doubt the pressure switch does. No expert here.
nehog
Jaffrey, NH
The shorter the length of wire, the more latitude you have to make it slightly smaller. Insulation temperature can also be a factor. For that usage, 12 AWG is acceptable.
