Compressor Pump Question
f575gtc
My current air pump doesn't seem to be cutting it for certain things. Sand blasting especially seems to strain the pump. Once the pump kicks on, it never recovers until I stop blasting for 30 seconds to 1 min.
Its rated at 13-4CFM @ 90PSI.
I am looking at two pumps, one is a 5HP 2 Stage pump capable of 17CFM @ 175PSI, I will not be using pressures that high, I cap my compressor at 125psi, I also don't think my tank can safely handle 175PSI.
The 2nd pump is a single stage 3 cylinder capable of about 18-20CFM @ 90PSI.
My motor is a true 5HP motor I can easily pull both pumps, both cost about the same the 2 stage is $50 more.
I mainly sand blast and spray cars with HVLP, but I also use air tools like impact guns etc.
Is the 2 stage the smart choice here? or would the single stage serve me better because it works around pressures I need?
Also what would 17CFM @ 175PSI translate to around 100PSI? will it be over 20CFM?
Thanks!
