Compressor Pump Teardown...RIP. Replacement?
b-body-bob
Almost Heaven
When I first got this compressor and fired it up, it was making a much worse noise. I had to tighten the flywheel set screw and that made it better. It's tight now, but making somewhat of the same noise.
I think I might pull the flywheel and check the key and keyway. I had to use a rubber mallet to get the flywheel on, and will need a puller to get it off, but maybe it's rotating on the shaft. I guess it's time to buy a puller instead of doing the free rental again.
You're only talking about the flywheel as a source, how about the motor sheave/pulley, have you checked that?
J
JonnyC
Green Bay, WI
Lol, dumb question here, but is it rotating in the correct direction?
Sometimes people don’t even think about it, or bother to check!
Not a dumb question for me, ha. I just went and checked and yes it's going in the right direction.
Yeah, that's on there real tight, and I can tell the noise is not coming from there.
J
JonnyC
Green Bay, WI
Well the key was mangled pretty bad.
Picked one up from the hardware store for $.80, and the thing is sounding a heck of a lot better. I'm actually quite surprised at how quiet this thing is.
C96
What RPM is that motor your running? Seems like she’s spinning awful fast.
Maybe I’m just used to hearing mine :lol_hitti
