JonnyC
I bought an older Campbell Hausfeld 5 hp 60 gallon compressor on the cheap from a local auto shop that was upgrading. This has a VT series pump (two cylinder in-line) that was weeping quite a bit of oil. I finally got it wired up last week and to my surprise it reached 120 psi and was generally functioning fine, but I wanted to freshen up the seals.
I ordered up a gasket kit before even tearing the pump down, which was a mistake. I took it apart tonight and saw major wear in the rear cylinder from the wrist pin...
Then looking at the head, I see part of the valve broke off and was partially blocking the exhaust port...
Granted it still functions, but it would be nice to get a new pump. Any advice? None come up on Craigslist by me. Most new ones are really expensive. The only options I was thinking of are:
1. Newer VT pump $250
2. NorthStar pump from Northern Tool $250
3. Polar / Eaton pump $250
4. HF for around $180
Or do I just say screw it, cut my losses, and buy a whole new compressor for around $500?
