Compressor Regulator
merlin1952
Eastern, NC
I have a new 80 gallon air compressor and I am looking for recommendations for a water-filter/regulator. It’s just for home use out in my workshop and will be mostly used for airing up tires, occasional impact wrench use, and typical around-the-home type stuff. I may eventually acquire a cheap paint gun to spray a few lawn mower parts or other type things , but I will never be a professional auto body man. I’m not looking to spend a fortune on a regulator just looking something to match my usage. Thanks.
lilredex
Toronto
Fisher type 64 regulator, 1/2" is a ggod one. I found a 1/4" was not big enough. Got mine free when I worked there sixty years ago....good quality stuff.
merlin1952
Eastern, NC
Yeah, a friend suggested the Harbor Freight Merlin model 58547 water filter regulator. I was just curious what others might recommend in a similar price range. Thanks,
johnre
Portland, OR
I like Pneumatic Plus; I've got the SAU320, but for the size of compressor you've got, probably the SAU420 model would be the best fit:
texasprd
San Antonio, TX
ARO (Ingersoll-Rand), Norgren, Fisher or Parker all good brands that should set you back too much money.
I have Sears-branded Norgren filter and lubricator units that I bought roughly 25 years ago (wow - it was that long ago?). Although I can find info sheets for these units online with part/kit numbers for repair o-ring kits, when I recently needed to replace bowl o-rings I found that those o-ring kits are either not easily available online or no longer available at all. I think I bought the very last o-ring kits that Grainger and some other company had. Whatever you get, make sure you can get parts like filter elements and bowl o-rings - you don't want to buy new units down the road because you can't get simple maintenance parts (and o-rings are so crazy-specific to try to match, in my experience).
merlin1952
Eastern, NC
I went by Harbor Freight this afternoon and bought the Merlin regulator. Hopefully I’ll get it installed tomorrow and we’ll see how it performs. I do appreciate everyone’s input. Thanks,
Mike65
Horse Pasture, Va.
merlin1952
Eastern, NC
Mike65, I purchased the blue industrial model ($99.99), but like I wrote I haven’t gotten it up and working just yet. I’m hoping to install it later today and get it adjusted up. Good luck with yours. Do let us know how everything works out for you.
Doozer75
Buffalo NY
The brand of water/particle filter and regulator do not matter.
Just stay away from something that is all plastic, like the body.
Most will have aluminum bodies. The best are brass.
You have heard the initialism, F-R-L, which stands for filter,
regulator, lubricator. Well this is kind of wrong.
What you really want is to put the regulator first, and then
the filter. The reason is, the regulator works with a needle and
seat, just like a carburetor or toilet valve. This causes the pressure
drop because of the restriction and an increase in air speed.
Both these things cause any moisture in the compressed air
to drop out of suspension. Another way to say, the regulator is
a natural moisture removal device. Everyone wants dry air, so
why not take advantage of this, and put the water/particle filter
after the regulator? Physics guarantees you will trap water if
you have a water/particle filter after the regulator.
So most of the time, these units have the water trap and particulate
filter combined. I get that. Makes a lot of sense. But you really
should protect the regulator, with its needle and seat, from
particulates. If you have a dedicated particle filter, that would be
best to put before the regulator. (Like a MotoGrard TP filter or
DeVilbiss painters filter). But barring that, just use a combination
water/particle filter.
So I am suggesting the best combination for moisture removal is:
Filter-Regulator-Filter
You will always see water in both filter traps, so why leave this free
moisture removal arrangement ignored ?
Now side note for regulators;
there are piston and diaphragm regulators.
If you need accurate pressure control, like for paint guns,
you need a diaphragm regulator. For air tools, the piston regulators
work fine.
But don't fall into this brand is better or this one is better.
Go off the mechanical specifications of what you are buying.
Opinions are for brands of motor oils and beers.
-Doozer
