jtbinvalrico
I've got a 60 gallon compressor. Made by Campbell Hausfeld. Tag indicates it was made in 2006. The cover for the pressure switch cracked, so I need to replace the whole switch (can't find just the cover). The only data plates on this unit are the red stamped one on the tank and the sticker on the motor. I'm pretty sure this was one of the Home Depot Husky units....but it's nice enough. USA motor, pump, etc. Bought it used around 2010. The model sticker and all that wasn't on it.
I'm trying to identify the proper switch for it. Entering the number off the switch housing I have now (DK641300AV, D-59320, and LR59232-3 are various numbers on stickers on the plastic housing) I'm directed toward a Condor MDR11 with more than a few variations listed on their website.
Here's what bothers me: The tank tag indicates a max working air pressure of 150 psi. When you find these switches for sale, some of them indicate a cut in and cut out psi of 120/155psi, respectively. Moreover, the safety valve installed on my compressor is @175psi.....Shouldn't the safety valve be more like 165psi?....(Max Working Air Pressure + 10%) FWIW, this compressor normally shuts off right at about 150-155 psi, no problems.
I think I have a four port switch. What did you replace the switch on your 60 gallon Husky compressor with? Shouldn't it be under the max rated air pressure? How about a safety valve set 25psi above the tank max? Is that normal?
I've attached some pictures and links. Thanks.
https://www.condor-usa.com/air-compressor-switches-mdr11-usa
