Compressor shut off switch.
ChevyEFI
Phoenix, AZ
My old reliable portable Craftsman 921.152100 has a leaking pressure switch that should hysically click it off. So it has endless leaking and run time if I let it run.
It's not individually called out in the blow-up of parts:
http://www.searspartsdirect.com/par...47/0703000?pathTaken=&prst=0&shdMod=921152100
It's at the end of the copper line and looks a lot like the one mounted to this manifold:
www.ebay.com/itm/221222433146
Is the serviceability of it such that I need to buy the whole manifold / switch as a unit? I've eBayed and googled a bit so far.
Thanks.
EOC_Jason
Bentonville, AR
Mine isn't exactly the same, but I was able to find just the brass flare fitting and schrader assembly somewhere, I don't remember if it was eBay or mastertoolrepair.
However, a whole new pressure switch assembly isn't that expensive either, as mentioned above they are like $20...
PhantomEB
Medicine Hat, AB, Canuckistan
20$ part and also is the reason I have my compressor on a switched on/off circuit right by the door. Neighbours don't like compressors running at night, so it was an easy solution.
signcrafter
Northern tool has a good selection of pressure switches. That's where I got mine.
C
ChevyEFI
Phoenix, AZ
It sounds like, based on their description, mine is the schraeder unloader valve.
http://www.mastertoolrepair.com/schrader-valve-ps1010rv-p-2307.html
The video they have on their site showing a test of the check valve was enlightening. I held my thumb over the ck valve and then it held to 90psi. So it's the unloader valve.
Yeah I could have ordered the valve assy. Bit I'm glad I did that test and I have another compressor to fix so the experience is fun.
C
ChevyEFI
Phoenix, AZ
Disassembled the valve and re-tefloned a couple fittings. Apparently the valve just h djunk in it. It's working. :)
