I was gifted a brand new Puma air compressor. It came wired for 110 but clearly states it can be rewired to 240. I already have the appropriate 240 circuit in my shop so I am switching it to 240. Based on the diagrams on the compressor itself, it appears the only changes I need to make are of course the plug and the wiring inside the motor. I have attached images of the two diagrams. One for the motor and the other for the pressure switch. The motor rewiring was straightforward. The pressure switch only has one diagram however and it is labeled both 110/240. Are no changes needed to the pressure switch wiring? It appears to be a single pole switch. The black terminals in the image below are connected. Only the white side is being switched.
Currently, if I plug it in and turn it on, it immediately blows the breaker. It is on a 30amp 240 circuit and the motor is only rated 7.5amps at 240 so I see no issue there.
