Compressors, Hoses, & Oil
Bolster
Mexifornia
I have one compressor (a Devilbiss 30 gal 3.5 HP). I oil my tools manually by putting oil into the air fitting of the tool before using the tool each day.
Can I assume that some of the oil goes back into the hose? Obviously oil would be very bad in a hose used for painting, so I have separate hoses for oiled tools, and for paint guns.
I need some extra hose length for an upcoming job. (No off-color jokes, please.) If I attach my 'clean' hose to the compressor, and then my 'oil' hose to the end of my 'clean' hose, do I risk contaminating my clean hose? (Remember, I don't use an inline oiler, so that oil would have to crawl back 25 feet through my 'oil' hose to get to my 'clean' hose.)
Also, is there any way of "cleaning" a hose of oil, if you suspect contamination? Or do you just buy a new one?
Any other advice on how to keep air tool oil (or any oil for that matter) out of my paint jobs? Had some dreaded fisheyes in my last spray job; was probably oil or silicone on the surface, but you never know...would hate to be throwing oil through my gun...
Red Green
South Central Michigan
How much oil are you putting in your tools that you are worried about oil back feeding? Do you need to run an air sander before you plan to spray? That should use any oil that is in the line or you could add a filter at the gun or between your clean hose and you hose that could have oil.
Bolster
Mexifornia
About 5 drops, which is what the mfg calls for in the instructions to the tool. Yes, usually running an air sander before spraying, exactly.
I like the idea of another filter between hoses, I think I'll do that. Thanks! :thumbup:
W-Cummins
Iowa
I use oil free hoses for spraying. I have 2 different styles of quick couplers and clean hose's and spray equipment have the "clean" style ends on them, and only plug into "clean" access points... That way you can't inadvertently use the wrong hose on the spray gun.
William...
